[Qgis-user] map frame questions
Luca Galuppini luca.galuppini at gmail.com
Thu Jul 23 02:14:47 PDT 2015
thank you for responses dear Andreas and Ujaval, i will try it asap.
by the way is there a way to save a print model into a portable file?
i work on my project on 2 different computers and also have a collaborator,
all files are in a dropbox, but the print project seems to be stored
locally.
2015-07-23 10:47 GMT+02:00 Neumann, Andreas <a.neumann at carto.net>:
> Hi,
> It would be better to use just a basic rectangle instead of an HTML frame
> with no content. There are basic shapes available, like rectangles,
> circles/ellipse and triangles. The icon for the basic shapes is next to the
> icon you use to add scalebars. You can lock the rectangle element after
> creation so it doesn't interfere with the selection of other elements.
> Andreas
> On 2015-07-23 10:36, Ujaval wrote:
>  For outer black border, you can add a new HTML frame with no content.
> It's a hack, but seems to work.
>> Geographic coordinates without seconds is possible. Use format 'Degree,
> Minute' and change coordinate precision to 0.
> On Tue, Jul 21, 2015 at 4:43 PM, Luca Galuppini <luca.galuppini at gmail.com>
> wrote:
>>    dear all
>> i am working on a map border, i would like to obtain a result similar to
>> this one:
>> http://www.giroparchi.it/it/cartadeisentieri/
>> only, i cannot find in the map composer the possibility to:
>> - add an outer black border 7-10 mm away from the actual map frame
>> - represent UTM coordinate values in thousands meters (ie 587 instead of
>> 587000)
>> - represent geographic coordinates without seconds (ie 44°15' instead of
>> 44°15'0")
>> is there a way to do it ?
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/e0d610b7/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/e0d610b7/attachment.png>
