[Qgis-user] Small maths problem!
Richard McDonnell richard.mcdonnell at opw.ie
Thu Jul 23 02:31:43 PDT 2015
Andreas,
Thanks for getting back, I have looked at similar ways to those outlined
by your good self, the only issue being, they all require the creation
of additional data or fields.
I will keep tipping away at it, once again, thanks for your help!
Regards,
Richard.
On 23/07/2015 10:01, Neumann, Andreas wrote:
> Hi Richard,
> It would be interesting to have this as a built-in feature of the
> "line pattern fill" renderer in QGIS: being able to specify an angle
> relative to the longest line segment of a polygon.
> I have the same issue for our black and white base map - see
> http://webgis.uster.ch/wsgi/webgisLauncher.wsgi?uuid=a6634a18-d37f-4997-b3d8-d4c3aed51716
> There we would like the line pattern fill angle to be 30 or 45 degrees
> relative to the longest side of a building. Currently all of these
> hatch-pattern fills are manually rotated ;-(
> Meanwhile - until such a feature is available in QGIS - you could
> preprocess your data with a Python script be decomposing your polygon
> data to individual line segments, find the longest ones and get their
> angles. I would probably save this in a data-column to speed up
> rendering. But you said you can't do this - so maybe you really have
> to calculate this on the fly.
> For data in Postgis one could write a plsql function to calculate
> these angles.
> Sorry that I can't be of better help here. Just showing that I also
> have in interest in such a feature.
> Andreas
> On 2015-07-23 10:10, Richard McDonnell wrote:
>> Hi,
>> I am in need of some guidance, I am trying to create an "active
>> hatch/Fill" as part of a style im working on. What I want is for a
>> hatch to rotate depending on the orientation of a Polygon.
>> For example, here is the same entity rotated, with the hatch rotating.
>> The issue is I am working on a database, onto which I cant add any
>> data (additional columns) to the tables, I would like to do this from
>> within the styling.
>> You can use an expression to denote the angle, so I was hoping to do
>> it that way.
>> I was looking to utilize the geometry of a bounding box, and
>> calculate the angle of the diagonal, using something like
>> 180*atan((ymax - ymin)/(xmax - xmin))/$pi + 90
>> But I am not having any luck....If there is no way at present to do
>> this, Might I put it forward as a possible new feature?
>> Regards,
>> Richard.
>> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
>> OPW - Looking to the future - Caring for the past
>> <http://www.opw.ie/>
>> Email Disclaimer: http://www.opw.ie/en/disclaimer/
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/f72217af/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/f72217af/attachment.png>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/f72217af/attachment.vcf>
