[Qgis-user] Small maths problem!
Andrew Harfoot
ajph at geodata.soton.ac.uk
Thu Jul 23 04:36:29 PDT 2015
Just a thought Richard, but if you don't need to edit the data, could
you not use a join to add a (precalculated) rotation field on the fly,
either on the DB side, or in QGIS?
Cheers,
Andy
On 23/07/2015 09:10, Richard McDonnell wrote:
> Hi,
> I am in need of some guidance, I am trying to create an "active
> hatch/Fill" as part of a style im working on. What I want is for a
> hatch to rotate depending on the orientation of a Polygon.
> For example, here is the same entity rotated, with the hatch rotating.
> The issue is I am working on a database, onto which I cant add any
> data (additional columns) to the tables, I would like to do this from
> within the styling.
> You can use an expression to denote the angle, so I was hoping to do
> it that way.
> I was looking to utilize the geometry of a bounding box, and calculate
> the angle of the diagonal, using something like
> 180*atan((ymax - ymin)/(xmax - xmin))/$pi + 90
> But I am not having any luck....If there is no way at present to do
> this, Might I put it forward as a possible new feature?
> Regards,
> Richard.
> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
> OPW - Looking to the future - Caring for the past
> <http://www.opw.ie/>
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> Qgis-user mailing list
Andy Harfoot
GeoData Institute
University of Southampton
Southampton
SO17 1BJ
Tel: +44 (0)23 8059 2719
Fax: +44 (0)23 8059 2849
www.geodata.soton.ac.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/eaccd080/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150723/eaccd080/attachment.png>
