[Qgis-user] Blank square appears when using basemap
David Fawcett
david.fawcett at gmail.com
Fri Jul 24 12:56:56 PDT 2015
This is a pretty well known issue: http://hub.qgis.org/issues/5827
On Fri, Jul 24, 2015 at 2:48 PM, Bernd Vogelgesang <bernd.vogelgesang at gmx.de
> wrote:
> Hi,
> Looks to me like the tiles from bing are not loaded during print time.
> I remember that fumbling in the settings->options->network made a
> difference with this kind of problems in the past.
> Not sure at all, but increase the value for time out (just add a zero) and
> also increase the max retry ... value.
> Maybe also increase the cache size (add zero) , but I'm not sure att all
> if those services are influenced by these values anyway.
> Others with better insight, please correct me.
> Cheers
> Bernd
> Am 24.07.2015, 20:24 Uhr, schrieb Susan Iremonger <s.iremonger at gmail.com>:
> Hi All,
> I keep getting an annoying (and time-consuming!) white square appearing in
> my map view when I use a basemap. I can get it to go away, generally, by
> changing the scale of view or turning items on and off in the table of
> contents, but it often just reappears and won't go away. Does anyone else
> have this problem, and have you cracked it?
> I attach a screenclip of the problem.
> Thanks a mil.
> Susan
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150724/1c2551a5/attachment.html>
