[Qgis-user] map frame questions
Luca Galuppini luca.galuppini at gmail.com
Sat Jul 25 06:35:42 PDT 2015
Dear Andreas and Ujaval
i could accomplish quite easily 2 of the 3 goals i had with the frame thing.
as per my wish to write coordinates in thousands format,i couldnt do it
unless using some complex workaround. it would be great to have a button
for building expression also near to the items in the print composer menu
(in my case, near the reticules>write coordinates>format menu), that would
make things a lot easier. is it a feature scheduled for next qgis version?
most pro maps frames dont read the whole metric coordinates like 1234000 N
or 567000 E:they only have thousands (1234, 567) and some even have smaller
and bigger numbers,see for example:
https://trekkingunpassoallavolta.files.wordpress.com/2014/08/determinare-coordinate-geografiche-base.jpg
or:
https://imageshack.com/f/4rparticolarej
it would be great to do the same in qgis out of the box, without graphic
postprocessing!
2015-07-23 11:38 GMT+02:00 Neumann, Andreas <a.neumann at carto.net>:
> Hi Luca,
> You can export a template file - but if you have linked files (such as
> images, logos, etc.) in your layout you will have to send those files
> along. In the print composer window -> Composer menu -> Save as Template.
> You might want to read the user manual if you are not so familiar with the
> concept of the print composer. Always a good idea to read the documentation
> Greetings,
> Andreas
> On 2015-07-23 11:14, Luca Galuppini wrote:
> thank you for responses dear Andreas and Ujaval, i will try it asap.
> by the way is there a way to save a print model into a portable file?
> i work on my project on 2 different computers and also have a
> collaborator, all files are in a dropbox, but the print project seems to be
> stored locally.
> 2015-07-23 10:47 GMT+02:00 Neumann, Andreas <a.neumann at carto.net>:
>>  Hi,
>> It would be better to use just a basic rectangle instead of an HTML frame
>> with no content. There are basic shapes available, like rectangles,
>> circles/ellipse and triangles. The icon for the basic shapes is next to the
>> icon you use to add scalebars. You can lock the rectangle element after
>> creation so it doesn't interfere with the selection of other elements.
>> Andreas
>> On 2015-07-23 10:36, Ujaval wrote:
>>  For outer black border, you can add a new HTML frame with no content.
>> It's a hack, but seems to work.
>>>> Geographic coordinates without seconds is possible. Use format 'Degree,
>> Minute' and change coordinate precision to 0.
>> On Tue, Jul 21, 2015 at 4:43 PM, Luca Galuppini <luca.galuppini at gmail.com
>> > wrote:
>>>    dear all
>>> i am working on a map border, i would like to obtain a result similar to
>>> this one:
>>> http://www.giroparchi.it/it/cartadeisentieri/
>>> only, i cannot find in the map composer the possibility to:
>>> - add an outer black border 7-10 mm away from the actual map frame
>>> - represent UTM coordinate values in thousands meters (ie 587 instead of
>>> 587000)
>>> - represent geographic coordinates without seconds (ie 44°15' instead of
>>> 44°15'0")
>>> is there a way to do it ?
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150725/98f15092/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150725/98f15092/attachment.png>
