[Qgis-user] Ubuntu: GRASS not working in the toolbox
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Fri Jul 31 06:19:00 PDT 2015
Hi thanx for your answer,
I think the problem lies within the latest processing version.
When I install QGIS with ubuntu unstable, it ships a rather old version of
processing 2.6. GRASS 7 working in the toolbox.
Then the plugin is recommended to be updated to 2.10.1 -> GRASS 7 not
working.
I then searched for other versions of processing, and there is the e.g.
the latest version before 2.10.1 available here for download:
Version 2.9.3
http://plugins.qgis.org/plugins/processing/version/2.9.3/download/
Extracted and copied to the plugins folder in .qgis2, replacing the 2.10.1
version, GRASS 7 works again.
The pity is, that in the new processing version, there is a new dissolve
polygons function with additional attribute operations available, which is
the missing link in a model I have to make, but either this works, or the
rest of my model (with GRASS algos).
Me and my co-workers do not want to update to QGIS 2.10 at the moment,
cause we would like to enjoy the Long Term Release, which is so far more a
Long Trouble Release for me ;)
Cheers
Bernd
Am 31.07.2015, 14:47 Uhr, schrieb Havard Tveite <havard.tveite at nmbu.no>:
> Hi Bernd,
> I don't know if you have had the same trouble as me.
> I am on Ubuntu 14.04.
> My problem was that in ubuntugis, the GRASS version was
> changed to 7.0, and I could not get that version to work
> with QGIS.
> To get QGIS 2.10 with a working GRASS in Processing, I
> removed qgis, grass and the lot. Then I removed ubuntugis
> from atp and made sure that qgis.org was in atp.
> I then installed the lot (qgis, grass, qgis-plugin-grass,
> python-qgis).
> After that, GRASS 6.4.3 was back and the GRASS commands
> were able to run through Processing with QGIS 2.10.
> Håvard
> On 25/7/2015 12:20:PM, Bernd Vogelgesang wrote:
>> Hi folks,
>> I would like to draw again your attention to my question, if there is
>> any working version of QGIS with GRASS available for Ubuntu at the
>> moment.
>> Not finding a working solution is frustrating, but it's even more
>> frustrating to receive no answers IF there is a working version at all
>> (If not, I could stop my trial-errorr-game and do other stuff).
>> So, once again. Does anyone using Ubuntu managed somehow to get a
>> recent version QGIS to cooperate with GRASS in the toolbox, and if yes,
>> HOW?
>> Thanx for your attention
>> Bernd
>> Am 22.07.2015, 16:00 Uhr, schrieb Bernd Vogelgesang
>> <bernd.vogelgesang at gmx.de>:
>> A pity,
>> but is there ANY version at the moment with working GRASS in the
>> toolbox under Ubuntu/Mint?
>> Just installed the dev-version from the ubuntugis nightly
>> repository. Same game here. GRASS not working
>> Cheers
>> Bernd
>> Am 21.07.2015, 11:56 Uhr, schrieb Filipe Dias
>> <filipesdias at gmail.com>:
>> Hi,
>> There is a bug filled on that issue. This issue come up a few
>> times over the past week.
>> http://hub.qgis.org/issues/13072
>> Cheers
>> On Tue, Jul 21, 2015 at 10:38 AM, Bernd Vogelgesang
>> <bernd.vogelgesang at gmx.de <mailto:bernd.vogelgesang at gmx.de>> wrote:
>> Hi,
>> am I really the only one with issues with processing.
>> I already thought that I solved the problem. On my machine
>> at home, I checked the repositories, reinstalled everything, updated
>> Processing and ... surprise surprise .. everything worked fine, even
>> after restarting QGIS several times.
>> But today when I wanted to resume with the project: Missing
>> dependency. This algorithm cannot be run :-(
>> How is that possible???
>> What can I do to check the circumstances? The provided link
>> doesn't help a lot
>> http://docs.qgis.org/testing/en/docs/user_manual/processing/3rdParty.html
>> Cheers
>> Bernd
>> Am 20.07.2015, 18:32 Uhr, schrieb Bernd Vogelgesang
>> <bernd.vogelgesang at gmx.de <mailto:bernd.vogelgesang at gmx.de>>:
>> Hi,
>> I'm going nuts! It took me weeks till a got a working
>> QGIS 2.8 install with GRASS(7) working in the toolbox on Linux
>> Mint/Ubuntu.
>> Using the model builder to create some workflow, I
>> became aware that there is a Processing update available.
>> Doing this update, the model doesn't work anymore,
>> cause GRASS stopped working in the toolbox.
>> When I do a fresh install without updating Processing,
>> I get an error when I try loading my model (which I unfortunately saved
>> with the new Processing version).
>> Ok, I could create that model again with the
>> non-updated Processing version, so the GRASS function I need is
>> available, but I also rely on the new "OGR Dissolve Polygons" function
>> introduced with the new Processing version, cause I need to sum up an
>> attribute while dissolving, and there is no alternative function at
>> hand.
>> Anyone an idea what to do? Seems I'm caught in kind of
>> a time/version hole.
>> Cheers
>> Bernd
>> Qgis-user mailing list
>> <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Bernd Vogelgesang
>> Siedlerstraße 2
>> 91083 Baiersdorf/Igelsdorf
>> Tel: 09133-825374
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> Bernd Vogelgesang
>> Siedlerstraße 2
>> Tel: 09133-825374
>> Bernd Vogelgesang
>> Siedlerstraße 2
>> Tel: 09133-825374
Bernd Vogelgesang
Siedlerstraße 2
Tel: 09133-825374
