[Qgis-user] Ubuntu: GRASS not working in the toolbox
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Fri Jul 31 08:14:07 PDT 2015
Ok, now I did as you described. qgis debian repo only.
GRASS works in Processing, but does not in a freshly created model.
Furthermore there is no SAGA available in the toolbox.
I simply would like to have back my fully working environment, like every
noob would have it on Windows without anything to do.
Bernd
Am 31.07.2015, 15:50 Uhr, schrieb Bernd Vogelgesang
<bernd.vogelgesang at gmx.de>:
> I don't know what's right or wrong anymore.
> I was sure that processing 2.93 had a working GRASS7 toolbox
> But this was with QGIS 2.8.2 some days ago.
> Now that I updated to 2.8.3, this also seems not to work anymore. This
> time, it's not complaining about missing GRASS, but the algos simply do
> run with errors and without result.
> Updating to processing 2.10.1 -> GRASS not available at all.
> Gnrrr
> Am 31.07.2015, 14:47 Uhr, schrieb Havard Tveite <havard.tveite at nmbu.no>:
>> Hi Bernd,
>> I don't know if you have had the same trouble as me.
>> I am on Ubuntu 14.04.
>> My problem was that in ubuntugis, the GRASS version was
>> changed to 7.0, and I could not get that version to work
>> with QGIS.
>> To get QGIS 2.10 with a working GRASS in Processing, I
>> removed qgis, grass and the lot.  Then I removed ubuntugis
>> from atp and made sure that qgis.org was in atp.
>> I then installed the lot (qgis, grass, qgis-plugin-grass,
>> python-qgis).
>> After that, GRASS 6.4.3 was back and the GRASS commands
>> were able to run through Processing with QGIS 2.10.
>> Håvard
>> On 25/7/2015 12:20:PM, Bernd Vogelgesang wrote:
>>> Hi folks,
>>> I would like to draw again your attention to my question, if there is
>>> any working version of QGIS with GRASS available for Ubuntu at the
>>> moment.
>>> Not finding a working solution is frustrating, but it's even more
>>> frustrating to receive no answers IF there is a working version at all
>>> (If not, I could stop my trial-errorr-game and do other stuff).
>>> So, once again. Does anyone using Ubuntu managed somehow to get a
>>> recent version QGIS to cooperate with GRASS in the toolbox, and if
>>> yes, HOW?
>>> Thanx for your attention
>>> Bernd
>>> Am 22.07.2015, 16:00 Uhr, schrieb Bernd Vogelgesang
>>>     A pity,
>>>     but is there ANY version at the moment with working GRASS in the
>>> toolbox under Ubuntu/Mint?
>>>     Just installed the dev-version from the ubuntugis nightly
>>> repository. Same game here. GRASS not working
>>>     Cheers
>>>     Bernd
>>>     Am 21.07.2015, 11:56 Uhr, schrieb Filipe Dias
>>> <filipesdias at gmail.com>:
>>>         Hi,
>>>         There is a bug filled on that issue. This issue come up a few
>>> times over the past week.
>>>         http://hub.qgis.org/issues/13072
>>>         Cheers
>>>         On Tue, Jul 21, 2015 at 10:38 AM, Bernd Vogelgesang
>>> <bernd.vogelgesang at gmx.de <mailto:bernd.vogelgesang at gmx.de>> wrote:
>>>             Hi,
>>>             am I really the only one with issues with processing.
>>>             I already thought that I solved the problem. On my machine
>>> at home, I checked the repositories, reinstalled everything, updated
>>> Processing and ... surprise surprise .. everything worked fine, even
>>> after restarting QGIS several times.
>>>             But today when I wanted to resume with the project:
>>> Missing dependency. This algorithm cannot be run :-(
>>>             How is that possible???
>>>             What can I do to check the circumstances? The provided
>>> link doesn't help a lot
>>> http://docs.qgis.org/testing/en/docs/user_manual/processing/3rdParty.html
>>>             Cheers
>>>             Bernd
>>>             Am 20.07.2015, 18:32 Uhr, schrieb Bernd Vogelgesang
>>> <bernd.vogelgesang at gmx.de <mailto:bernd.vogelgesang at gmx.de>>:
>>>                 Hi,
>>>                 I'm going nuts! It took me weeks till a got a working
>>> QGIS 2.8 install with GRASS(7) working in the toolbox on Linux
>>> Mint/Ubuntu.
>>>                 Using the model builder to create some workflow, I
>>> became aware that there is a Processing update available.
>>>                 Doing this update, the model doesn't work anymore,
>>> cause GRASS stopped working in the toolbox.
>>>                 When I do a fresh install without updating Processing,
>>> I get an error when I try loading my model (which I unfortunately
>>> saved with the new Processing version).
>>>                 Ok, I could create that model again with the
>>> non-updated Processing version, so the GRASS function I need is
>>> available, but I also rely on the new "OGR Dissolve Polygons" function
>>> introduced with the new Processing version, cause I need to sum up an
>>> attribute while dissolving, and there is no alternative function at
>>> hand.
>>>                 Anyone an idea what to do? Seems I'm caught in kind of
>>> a time/version hole.
>>>                 Cheers
>>>                 Bernd
>>>                 _______________________________________________
>>>                 Qgis-user mailing list
>>>                 Qgis-user at lists.osgeo.org
>>> <mailto:Qgis-user at lists.osgeo.org>
>>>                 http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>             Bernd Vogelgesang
>>>             Siedlerstraße 2
>>>             91083 Baiersdorf/Igelsdorf
>>>             Tel: 09133-825374
>>>     Bernd Vogelgesang
>>>     Siedlerstraße 2
>>>     Tel: 09133-825374
>>> Bernd Vogelgesang
>>> Siedlerstraße 2
>>> Tel: 09133-825374
Bernd Vogelgesang
Siedlerstraße 2
Tel: 09133-825374
