[Qgis-user] QGIS 2.6 or 2.8 GRASS 7 compatibility
Ivan Santiago
isantiago at ogp.pr.gov
Tue Mar 3 12:57:53 PST 2015
Hello all:
I'm using QGIS 2.6.1 and tried to open GRASS 7 vector layers without luck.
The map name appears but not the layer number.
Does QGIS 2.8 read GRASS 7 layers?
Ivan Santiago
Especialista en Sistemas de Informaci?n Geogr?fica
?rea de Tecnolog?as de Informaci?n
Oficina de Gerencia y Presupuesto
Tel.:(787) 725 9420 x 2417
Email: isantiago at ogp.pr.gov
Web: http://www.ogp.pr.gov
[http://www.ogp.pr.gov/logos.png]
NOTA DE CONFIDENCIALIDAD: Esta transmisi?n electr?nica contiene informaci?n perteneciente a la Oficina de Gerencia y Presupuesto, que es confidencial, privilegiada y/o privada bajo las leyes aplicables. Se utiliza solamente para el uso de la persona o entidad que se dirige. Si usted no es el destinatario intencional, se le notifica que se proh?be cualquier uso, diseminaci?n o copia de esta comunicaci?n. Si usted recibe esta comunicaci?n por error, favor de notificar al remitente y eliminar este correo electr?nico de su sistema.
CONFIDENTIALITY NOTE: This electronic transmission contains information belonging to the Office of Management and Budget, which is confidential, privileged and exempt from disclosure under applicable law. It is intended solely for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are hereby notified that any use, dissemination, or copying of the communication is strictly prohibited. If you have received this communication by error, please notify the sender and delete this e-mail from your system.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150303/f9075dec/attachment.html>
