[Qgis-user] GPR-maps
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Mar 17 05:10:20 PDT 2015
Qgis is moving faster than they can make the manuals.  2.8.1 is out but the manual are mostly translate and finished for 2.6.  If you are lost, try installing 2.6.  There is the software manual but also the introduction guide and the training manual that is great for learning. http://www.qgis.org/en/docs/  Qgis 2.8 should not be that different but that depends on your learning curve.
 Lost of stuff on YouTube in you prefer learning with video.
If your GPR survey is georeferenced, then all you need to do is to open the Map Composer. If not, it will need to be georeferenced first.
 http://docs.qgis.org/2.6/en/docs/training_manual/map_composer/map_composer.html
Add a map, (GPR survey with houses and background) then click on the frame.  You will see on the right hand side options for adding a grid. More example here.
http://gis.stackexchange.com/questions/31200/grid-and-graticule-in-qgis-print-composer
For Qgis 2.6, the Grid will be in your project CRS.  In Qgis 2.8, I think you can use an alternative grid.
Good luck
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
Le 2015-03-17 07:17, "Christer Andersson [via OSGeo.org]	" <ml-node+s1560n5193850h11 at n6.nabble.com> a écrit :
Hi, can anybody give an advice how to make a map of a ground penetrating radar investigation of 15x20 meter, where I know the longitudes and latitudes of the four corners in the rectangle. I would like to have latitude and longitude along the sides of the map too. Can I use a map where there already are drawn some houses? It is extremely hard to learn from the manual. The instructions do not always correspond with Qgis 2.8.1. I would be very grateful for some help to get along with this. /Christer
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/GPR-maps-tp5193850.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/GPR-maps-tp5193850p5193863.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150317/8e8e22d8/attachment.html>
