[Qgis-user] QGIS 64-bit, Processing Toolbox and Grass 7
Radim Blazek
radim.blazek at gmail.com
Mon May 4 00:04:12 PDT 2015
On Tue, Apr 14, 2015 at 11:29 PM, Saulteau Don <sault.don at gmail.com> wrote:
> There's a crowdfunding campaign[1] underway to get QGIS updated for GRASS 7.
> So yes, like Jose pointed out, some of the grass7 tools in processing will have errors.
> You can compile QGIS without any of the cmake options for GRASS, because I think those are only if you want to have the GRASS plugin (that toolbar).
> If you want GRASS 7 in Processing, you can update the providers in the processing options and also double check that the needed env vars[2][3] for GRASS exist.
> Upgrading the toolbar for GRASS7 support is also part of the crowd funding too.
Yes, the plugin upgrade is underway but there is yet no GRASS 7 64bit
in OSGEO4W. The GRASS 7 plugin in OSGEO4W wont be available until the
GRASS 7 64bit itself appears there.
Radim
> [1] http://www.gissula.eu/qgis-grass-plugin-crowdfunding/
> [2] http://grass.osgeo.org/grass70/manuals/variables.html
> [3] http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
> On Mon, Apr 13, 2015 at 2:08 AM, José Antonio Barreña Cayuela <jabarcay at gmail.com> wrote:
>> Adrian,
>> My solution was to install grass64 and edit qgis pkbuild for this grass version (look commnents in https://aur.archlinux.org/packages/qgis/).
>> The grass does not work environment. Processing seems to work but in tests I've done gives me errors.
>> El 12/04/15 a las 21:30, Adrian Wooster escribió:
>> I'm finding I need to use the 64-bit version of QGIS for some of my
>> bigger models but I miss the ability to use Grass 7 without having to
>> drop out to load it natively.
>> I recognise that there are issues for the developers in embedding
>> Grass 7 within the OSGEO4Win 64-bit package, but is anyone aware of a
>> mechanism to configure the 64-bit version of QGIS (2.8/9) to load
>> Grass 7 modules from a standalone installation via the Processing
>> Toolbox?
>> I have both installed on my system but haven't been able to find a
>> set-up where Processing will recognise the Grass 7 installation.
>> Regards,
>> Adrian
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Biólogo (botánico). Servicios Medioambientales
>> +34 677 811 883 · jabarcay at gmail.com
