[Qgis-user] [QGIS-UX] QGIS fonts in print composer
Sarah Van Vliet
sarahvvv at gmail.com
Wed May 6 00:13:10 PDT 2015
Hi Donovan,
Thanks so much for looking into this.
The problem is that certain weights and widths are not available at a given font size. So at font size 14 you might be able to use wide book but not news.
If a text box is in a certain size and width/weight, and you change the font size, it will default into a different width/weight if the current one doesn't work with the new font size.
The strange part is that all my colleagues and I are seeing different width/weight/font size availability.
If you try using clan pro news in all font sizes and it doesn't change weight/width, I may just need to update my qgis version
Sent from my iPhone
> On May 5, 2015, at 3:27 AM, Donovan Cameron <sault.don at gmail.com> wrote:
> Sarah,
> I haven't had any issues with the Clan Pro font you provided. I tried displaying labels for a point file at various sizes in pt and but didn't play with the style (ie, medium, wide, narrow, etc...). They looked fine in Print Composer too.
> Can you maybe explain more on what you mean by "some of the fonts work"?
> I'm running QGIS 2.8.1, is it possible for you and your team to upgrade to the latest version of QGIS for testing?
> Donovan
>> On 01/05/15 08:46 AM, Sarah Van Vliet wrote:
>> Thanks Anita,
>> qgis-ux to bcc
>> Hi qgis user mailing list,
>> My team and I are having trouble with fonts in qgis print composer. we all have various versions as we all joined at different times. ( i use 2.4.0, while one other colleague uses 2.6.1, etc. ). We use a font set called Clan Pro, and only some of the fonts work at any given font size. What's more, which fonts work and don't seems to vary amongst all of us!
>> I've attached the font set for debugging purposes as well.
>> does anybody know a solution? is there some version of qgis where fonts are better functioning?
>> Thanks,
>> Sarah
>>> On Thu, Apr 30, 2015 at 12:48 PM, Anita Graser <anitagraser at gmx.at> wrote:
>>> Hi Sarah,
>>> I'm afraid this does not seem like a question for the usability mailing list. Please use the user mailing list for problems relating to the use of certain QGIS features. Also, can you provide the font you mentioned for debugging purposes?
>>> Best wishes,
>>> Anita
>>> On Thu, Apr 30, 2015 at 8:25 PM, Sarah Van Vliet <sarahvvv at gmail.com> wrote:
>>>> Hi qgis community,
>>>> Thanks,
>>>> Sarah
>>>> _______________________________________________
>>>> QGIS-UX mailing list
>>>> QGIS-UX at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/qgis-ux
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150506/e7656da0/attachment.html>
