[Qgis-user] Open street map
Tony Bazeley tonyb at sa.apana.org.au
Fri May 8 16:46:49 PDT 2015
On 09/05/15 06:24, JOE LEMONNIER wrote:
> I've download the OSM data from Vector>open street map> download data. Then imported the topology from xml then exported to Spatialite specifying poly lines. When do this for the span of lower Manhattan in New York City, I get a beautiful set of map data that is unfortunately missing quite a few major streets. Exporting as polygons doesn't omit those streets from the map but I need the center lines. Importing the .osm file directly gives the same results of missing  streets. I've tried 4 times with same results.
> What am I doing wrong?
> Sent from iPhone
I had a similar problem and switched to postgresql/postgis
I think the spatialite import facility is broken
Tony
