[Qgis-user] Open street map
JOE LEMONNIER jlemonnier at mac.com
Fri May 8 13:54:36 PDT 2015
I've download the OSM data from Vector>open street map> download data. Then imported the topology from xml then exported to Spatialite specifying poly lines. When do this for the span of lower Manhattan in New York City, I get a beautiful set of map data that is unfortunately missing quite a few major streets. Exporting as polygons doesn't omit those streets from the map but I need the center lines. Importing the .osm file directly gives the same results of missing  streets. I've tried 4 times with same results.
What am I doing wrong?
Sent from iPhone
> On May 8, 2015, at 3:02 PM, qgis-user-request at lists.osgeo.org wrote:
> Send Qgis-user mailing list submissions to
>    qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>    http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>    qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>   1. Segmentation fault at start (emmexx)
>   2. blue marble and similar wms (Michael.Dodd)
>   3. base maps (Dayna LeClair)
>   4. Re: base maps (James Keener)
> Message: 1
> Date: Fri, 08 May 2015 12:14:55 +0200
> From: emmexx <emmexx at tiscalinet.it>
> To: "'qgis-user at lists.osgeo.org'" <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Segmentation fault at start
> Message-ID: <554C8C9F.5060509 at tiscalinet.it>
> Content-Type: text/plain; charset=UTF-8; format=flowed
> I'm using a qgis-master version in parallel with qgis 2.6 on linux
> slackware 14.1.
> I used the qgis-master a few times with no problem. A few minutes ago I
> used it to load a wfs layer from a geoserver and edit a feature. I
> closed it and now I get a segmentation fault:
> ./qgis
> Running from build directory!
> - source directory: /home/myuser/QGIS-master/QGIS-master
> - output directory of the build:
> /home/myuser/QGIS-master/QGIS-master/build-master/output
> Warning: loading of qgis translation failed
> [/home/myuser/QGIS-master/QGIS-master/build-master/output/i18n/qgis_en_US]
> Warning: loading of qt translation failed
> [/usr/lib/qt/translations/qt_en_US]
> Warning: !!! prefix path was requested, but it is not valid - we do not
> run from installed path !!!
> Warning: QObject: Cannot create children for a parent that is in a
> different thread.
> (Parent is QgsNetworkAccessManager(0xa832958), parent's thread is
> QThread(0xa706570), current thread is QThread(0xbb76088)
> Segmentation fault
> Qgis 2.6 works as expected.
> What should I check/delete/restore?
> Thank you
>    maxx
> Message: 2
> Date: Fri, 8 May 2015 13:16:44 +0000
> From: Michael.Dodd <michael.dodd at open.ac.uk>
> Subject: [Qgis-user] blue marble and similar wms
> Message-ID:
>    <52F173986979BD41AE31A411151FFF8717139579 at EX10-MBX-LIVE-B.open.ac.uk>
> Content-Type: text/plain; charset="iso-8859-1"
> I am looking for a creative commons or similar background image to use with OSM vector data. There are options via openlayers and wms but can't find one that has suitable imagery without labels.
> I am looking for something only at low resolution for background to New Zealand map.  There are loads of possibilities via LINZ but none provide a general topo image or similar suitable for whole country that looks reasonable as a map background (e.g. the terrain relief map is in big blocks and do not seem to be able to select out the coastline using vector to tidy up the edges, qgis raster clipper simply says the coastline shapefile or any other shapefile will not work to cut the raster).
> Is there a wms providing blue marble data or a way of georeferencing the downloadable blue marble image files?
> -- The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302). The Open University is authorised and regulated by the Financial Conduct Authority.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150508/f67af29e/attachment-0001.html>
> Message: 3
> Date: Fri, 8 May 2015 14:43:18 -0400
> From: Dayna LeClair <dayna.leclair at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] base maps
> Message-ID:
>    <CAEkRvS_mtyXOGtkXaFYoE-5t1BVgvP1kqKu4Ae3Z00MS8vrn+g at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hello,
> I work for an environmental consulting company. We use to outsource our
> maps to a local design firm that has recently closed down. I am starting to
> tackle the maps and figures we create for clients and thought that I could
> use QGIS. I have some GIS experience, however it was many years ago. I have
> gone through the tutorial and feel comfortable. But not that I am trying to
> work on my own project I have hit a road block. I cannot find/import/upload
> a map for anywhere in Ontario, Canada. I have loaded open layers, but I
> would like to manipulate different layers, and choose what to show and what
> not to show. I assume this is not possible in open layers as there are no
> vectors listed under Google Street. A little help/ guidance would be much
> appreciate.
> Thank you so much
> Dayna LeClair, MSc
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150508/9b2486aa/attachment-0001.html>
> Message: 4
> Date: Fri, 08 May 2015 14:46:57 -0400
> From: James Keener <jim at jimkeener.com>
> To: Dayna LeClair <dayna.leclair at gmail.com>, qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] base maps
> Message-ID: <554D04A1.9000809 at jimkeener.com>
> Content-Type: text/plain; charset=windows-1252
> Would you be able to import the OpenStreetMaps data and manipulate it as
> you wish if you chose not to use the default OSM layer as your basemap?
> Jim
> End of Qgis-user Digest, Vol 111, Issue 13
