[Qgis-user] OSGeo4W's QGIS Web Server install problem. “Not Found ... qgis_mapserv.fcgi”
Andre Joost andre+joost at nurfuerspam.de
Fri May 8 23:50:45 PDT 2015
Am 08.05.2015 um 21:16 schrieb dennis mckay:
> Question:  Does qgis_mapserv.fgci.exe return good debugging info if run from command line?
> Question:  What is the format for passing parameters to qgis_mapserv.fgci.exe in the command line?
> Question:  In Apache .conf files, can quotes in path names be dropped if there are no spaces?
> The Real Question:  Why does my browser not find qgis_mapserver.fgci.exe?
I strongly recommend to stick to one architecture.
Since OSGEO4W 64-bit does not include apache (see
<http://download.osgeo.org/osgeo4w/versions_diff-x86-x86_64.html>) , I
suggest to run everything on 32-bit, as included in the OSGEO4W
packages. A mixture of 64-bit and 32-bit software will most likely run
into problems at one point.
HTH,
André Joost
