[Qgis-user] projection confused during import from Grass to QGIS
Randal Hale
rjhale at northrivergeographic.com
Mon May 11 14:20:50 PDT 2015
Shouldn't your east and west Lattitudes be negative? That would make it
appear reversed as they stand now. At least I think - but I've not done
what you are doing.
Randy
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
http://www.northrivergeographic.com/introduction-to-quantum-gis
On 05/11/2015 05:11 PM, Tyler Smith wrote:
> Hi,
> I'm exporting some data from Grass 6.4 to QGis as .asc files. The source
> location in Grass has the projection:
> g.proj -p
> -PROJ_INFO-------------------------------------------------
> proj : ll
> datum : wgs84
> ellps : wgs84
> no_defs : defined
> -PROJ_UNITS------------------------------------------------
> unit : degree
> units : degrees
> meters : 1.0
> I generated the asc file from Grass with:
> r.out.ascii input=tri_median at PERMANENT output=tri_median.asc
> When I import this into QGis, the layer is flipped east to west - the
> atlantic coast of NA appears on the west, rather than the east!
> The header appears correct:
> tws:~$ head -6 tri_mean.asc
> north: 46:53:04.633938N
> south: 34:44:13.536462N
> east: 68:50:28.1616W
> west: 94:51:40.938811W
> rows: 1458
> cols: 3122
> But gdal mis-reads it:
> tws:~$ gdalinfo tri_mean.asc
> Driver: GRASSASCIIGrid/GRASS ASCII Grid
> Files: tri_mean.asc
> Size is 3122, 1458
> Coordinate System is `'
> Origin = (94.000000000000000,46.000000000000000)
> Pixel Size = (-0.008327994875080,-0.008230452674897)
> Corner Coordinates:
> Upper Left ( 94.0000000, 46.0000000)
> Lower Left ( 94.0000000, 34.0000000)
> Upper Right ( 68.0000000, 46.0000000)
> Lower Right ( 68.0000000, 34.0000000)
> Center ( 81.0000000, 40.0000000)
> Band 1 Block=3122x1 Type=Float32, ColorInterp=Undefined
> I also tried opening this map directly from Grass within QGIS using the
> Grass plugin. The problem persists - the projection of the map is
> flipped east to west when it appears in QGIS.
> Have I done something wrong somewhere, or is there a problem with the
> Grass 6.4 export or QGis/gdal import?
> Thanks!
