[Qgis-user] getPrint qgis_mapserver.fcgi
Andreas Neumann a.neumann at carto.net
Wed May 13 02:07:57 PDT 2015
Hi Dieter,
Is there a X-Server running on the server? Printing to PDF requires the
X-Server and a configuration variable in the FCGID conf.
See also http://www.itopen.it/qgis-server-setup-notes/
Andreas
On 13.05.2015 10:57, dieter_lehmann wrote:
> Hello,
> I have some problems using the getPrint Request with
> qgis_mapserver.fcgi (on Ubuntu 14.04.2 LTS, qgis-server version:
> 2.8.2+20trusty) - installed via the repro from qgis.org.
> Printing as PDF with Qgis is working on this machine without problems.
> Sending the getPrint Request (f.g. through qgis-webclient), an
> internal Server error occur. In the qgis-server log shows the follwing
> up:
> End of script output before headers: qgis_mapserv.fcgi...
> When I change the request to create a PNG, at least the map without
> legend is shown, but the layout is corrupted.
> Any ideas?
> Thanks a lot,
> Dieter
> Qgis-user mailing list
