[Qgis-user] getPrint qgis_mapserver.fcgi
dieter_lehmann dieter_lehmann at web.de
Wed May 13 02:49:14 PDT 2015
Hi Andreas,
thanks for the hint, I've installed xvfb, changed fcgid.conf, started
xvfb, restarted apache -  with no luck.
Xvfb is running with :99
Same error as before.
Dieter
Am 13.05.2015 um 11:07 schrieb Andreas Neumann:
> Hi Dieter,
> Is there a X-Server running on the server? Printing to PDF requires
> the X-Server and a configuration variable in the FCGID conf.
> See also http://www.itopen.it/qgis-server-setup-notes/
> Andreas
> On 13.05.2015 10:57, dieter_lehmann wrote:
>> Hello,
>> I have some problems using the getPrint Request with
>> qgis_mapserver.fcgi (on Ubuntu 14.04.2 LTS, qgis-server version:
>> 2.8.2+20trusty) - installed via the repro from qgis.org.
>> Printing as PDF with Qgis is working on this machine without problems.
>> Sending the getPrint Request (f.g. through qgis-webclient), an
>> internal Server error occur. In the qgis-server log shows the
>> follwing up:
>> End of script output before headers: qgis_mapserv.fcgi...
>> When I change the request to create a PNG, at least the map without
>> legend is shown, but the layout is corrupted.
>> Any ideas?
>> Thanks a lot,
>> Dieter
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
