[Qgis-user] getPrint qgis_mapserver.fcgi
dieter_lehmann dieter_lehmann at web.de
Wed May 13 11:55:39 PDT 2015
Hi Andreas,
just thinking about your comment with the firewall: do you know, what
connections should work?
Cause I'm sitting on a fairly restricted system with a firewall sitting
in front of my server. My local server has no firewall rules active.
Thanks,
Dieter
Am 13.05.2015 um 11:49 schrieb dieter_lehmann:
> Hi Andreas,
> thanks for the hint, I've installed xvfb, changed fcgid.conf, started
> xvfb, restarted apache -  with no luck.
> Xvfb is running with :99
> Same error as before.
> Dieter
> Am 13.05.2015 um 11:07 schrieb Andreas Neumann:
>> Hi Dieter,
>> Is there a X-Server running on the server? Printing to PDF requires
>> the X-Server and a configuration variable in the FCGID conf.
>> See also http://www.itopen.it/qgis-server-setup-notes/
>> Andreas
>> On 13.05.2015 10:57, dieter_lehmann wrote:
>>> Hello,
>>> I have some problems using the getPrint Request with
>>> qgis_mapserver.fcgi (on Ubuntu 14.04.2 LTS, qgis-server version:
>>> 2.8.2+20trusty) - installed via the repro from qgis.org.
>>> Printing as PDF with Qgis is working on this machine without problems.
>>> Sending the getPrint Request (f.g. through qgis-webclient), an
>>> internal Server error occur. In the qgis-server log shows the
>>> follwing up:
>>> End of script output before headers: qgis_mapserv.fcgi...
>>> When I change the request to create a PNG, at least the map without
>>> legend is shown, but the layout is corrupted.
>>> Any ideas?
>>> Thanks a lot,
>>> Dieter
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
