[Qgis-user] Multy field labels
Irakli Ugulava i.ugulava at gmail.com
Fri May 15 08:17:06 PDT 2015
Thanks a lot,
I combine both advises, and get at last this
CASE WHEN "NAME_GEO" IS NOT NULL THEN CONCAT ("NAME_GEO", "ELEV") ELSE
"ELEV" END
it works at last
Thanks a lot :)
On Fri, May 15, 2015 at 6:29 PM, Andreas Neumann <a.neumann at carto.net>
wrote:
>  Hi,
> You need to use COALESCE(labelfield,'alternate text')
> If the label contains data, the data is used, if it contains NULL, the
> alternate text is displayed, which often is an empty string, a replacement
> text or another field.
> In your case, you could use:
> COALESCE("NAME_GEO" || '(' || elev || ')','elev')
> In case it has a name, the name is displayed with elevation, if it is
> null, then the elevation is displayed.
> This is the same syntax like SQL is using.
> Hope this helps,
> Andreas
> On 15.05.2015 16:01, Irakli Ugulava wrote:
> For physical map need to label summits and elevation points, some of them
> have name some no, so I need to label them from different fields.
>  when I use expression :
>  "NAME_GEO"   ||  "elev"
>  It works, but summits with no names, (field "NAME_GEO" is empty), has no
> label at all, according to ArcGis logic they should have only elevation on
> labels.
>  I try following expression
> CASE WHEN "name_geo" is null   THEN "NAME_GEO"   ||   "ELEV"  ELSE "elev"
>  but it return no labels at all.
>  Thanks All
> Irakli Ugulava
> Senior GIS Expert, Cofounder
> GeoLand Ltd.
> 3 Telegraph Cule-de-sac
> Tbilisi 0105, Georgia,
> Tel:  +995 32 922553
> Mob +995 99 172016
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
Irakli Ugulava
GeoLand Ltd.
Tel:  +995 32 922553
Mob +995 99 172016
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150515/289871e1/attachment.html>
