[Qgis-user] Python Error message: meaning?
Joris Hintjens jorishin at gmail.com
Sat May 16 09:50:53 PDT 2015
Hello,
When loading a project, I get the following error message for each layer that is loading:
 what does it mean, how to repair or get rid of these messages?
I have the impression that everything works OK after closing these messages
thanks for your comments.
Joris
Error message:
Er is een fout opgetreden bij het uitvoeren van Python code:
  File "/Users/joris/.qgis2/python/plugins/redLayer/redLayerModule.py", line 368, in notSavedProjectAction
    QgsMapLayerRegistry.instance().legendLayersAdded.disconnect(self.notSavedProjectAction)
TypeError: disconnect() failed between 'legendLayersAdded' and 'unislot'
Python versie:
2.7.6 (default, Sep  9 2014, 15:04:36)
[GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.39)]
QGIS versie:
2.8.1-Wien Wien,
Python pad: ['/Users/joris/.qgis2/python/plugins/navidata', '/Users/joris/.qgis2/python/plugins/processing', '/Users/joris/.qgis2/python/plugins/GeoCoding/libs', '/Applications/QGIS.app/Contents/MacOS/../Resources/python', u'/Users/joris/.qgis2/python', u'/Users/joris/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7', '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Python/2.7/site-packages/matplotlib-override', '/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Library/Python/2.7/site-packages/PIL', u'/Users/joris/.qgis2//python', '/Users/joris/.qgis2/python/plugins/geopunt4Qgis/ext-libs', '/Users/joris/.qgis2/python/plugins/mmqgis/forms', '.', '/Users/joris/.qgis2/python/plugins/QuickMultiAttributeEdit/forms', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150516/430fdf47/attachment.html>
