[Qgis-user] R: Python Error message: meaning?
Enrico Ferreguti enricofer at gmail.com
Sat May 16 10:07:44 PDT 2015
The error messages are generated from redLayer plugin. Submit it to plugin issue tracker. Try to update the plugin and reload qgis. If it does not resolv unload it.
----- Messaggio originale -----
Da: "Joris Hintjens" <jorishin at gmail.com>
Inviato: ‎16/‎05/‎2015 18:51
A: "QGIS User" <Qgis-user at lists.osgeo.org>
Oggetto: [Qgis-user] Python Error message: meaning?
Hello,
When loading a project, I get the following error message for each layer that is loading:
 what does it mean, how to repair or get rid of these messages?
I have the impression that everything works OK after closing these messages
thanks for your comments.
Joris
Error message:
Er is een fout opgetreden bij het uitvoeren van Python code:
Traceback (most recent call last):  File "/Users/joris/.qgis2/python/plugins/redLayer/redLayerModule.py", line 368, in notSavedProjectAction    QgsMapLayerRegistry.instance().legendLayersAdded.disconnect(self.notSavedProjectAction)TypeError: disconnect() failed between 'legendLayersAdded' and 'unislot'
Python versie:
2.7.6 (default, Sep  9 2014, 15:04:36)
[GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.39)]
QGIS versie:
2.8.1-Wien Wien,
Python pad: ['/Users/joris/.qgis2/python/plugins/navidata', '/Users/joris/.qgis2/python/plugins/processing', '/Users/joris/.qgis2/python/plugins/GeoCoding/libs', '/Applications/QGIS.app/Contents/MacOS/../Resources/python', u'/Users/joris/.qgis2/python', u'/Users/joris/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7', '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Python/2.7/site-packages/matplotlib-override', '/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Library/Python/2.7/site-packages/PIL', u'/Users/joris/.qgis2//python', '/Users/joris/.qgis2/python/plugins/geopunt4Qgis/ext-libs', '/Users/joris/.qgis2/python/plugins/mmqgis/forms', '.', '/Users/joris/.qgis2/python/plugins/QuickMultiAttributeEdit/forms', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150516/ce07d042/attachment.html>
