[Qgis-user] Python Error message: meaning?
Joris Hintjens jorishin at gmail.com
Sun May 17 09:21:57 PDT 2015
Thanks Enrico;
I unchecked the plugin and no more problem. Sorry that I cannot use your nice plugin for some time.
Joris
> Op 16-mei-2015, om 19:07 heeft Enrico Ferreguti <enricofer at gmail.com> het volgende geschreven:
> The error messages are generated from redLayer plugin. Submit it to plugin issue tracker. Try to update the plugin and reload qgis. If it does not resolv unload it.
> Da: Joris Hintjens <mailto:jorishin at gmail.com>
> Inviato: ‎16/‎05/‎2015 18:51
> A: QGIS User <mailto:Qgis-user at lists.osgeo.org>
> Oggetto: [Qgis-user] Python Error message: meaning?
> Hello,
> When loading a project, I get the following error message for each layer that is loading:
>  what does it mean, how to repair or get rid of these messages?
> I have the impression that everything works OK after closing these messages
> thanks for your comments.
> Joris
> Error message:
> Er is een fout opgetreden bij het uitvoeren van Python code:
> Traceback (most recent call last):
>   File "/Users/joris/.qgis2/python/plugins/redLayer/redLayerModule.py", line 368, in notSavedProjectAction
>     QgsMapLayerRegistry.instance().legendLayersAdded.disconnect(self.notSavedProjectAction)
> TypeError: disconnect() failed between 'legendLayersAdded' and 'unislot'
> Python versie:
> 2.7.6 (default, Sep  9 2014, 15:04:36)
> [GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.39)]
> QGIS versie:
> 2.8.1-Wien Wien,
> Python pad: ['/Users/joris/.qgis2/python/plugins/navidata', '/Users/joris/.qgis2/python/plugins/processing', '/Users/joris/.qgis2/python/plugins/GeoCoding/libs', '/Applications/QGIS.app/Contents/MacOS/../Resources/python', u'/Users/joris/.qgis2/python', u'/Users/joris/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7', '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Python/2.7/site-packages/matplotlib-override', '/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Library/Python/2.7/site-packages/PIL', u'/Users/joris/.qgis2//python', '/Users/joris/.qgis2/python/plugins/geopunt4Qgis/ext-libs', '/Users/joris/.qgis2/python/plugins/mmqgis/forms', '.', '/Users/joris/.qgis2/python/plugins/QuickMultiAttributeEdit/forms', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150517/3b299032/attachment.html>
