[Qgis-user] Error installing QGIS 2.8.2-1 on Mac
Jacopo Tonetti jacopotonetti at gmail.com
Tue May 19 13:23:33 PDT 2015
Hi, seems that you have an older version of PROJ library. Did you download
the package or install via homebrew? I recommend the latter (but you should
use command line), I followed this
<https://github.com/OSGeo/homebrew-osgeo4mac/wiki/Developing-on-QGIS-using-OSGeo4Mac>
guide and everything is fine, same OS and version of QGIS.
j
2015-05-19 19:38 GMT+02:00 Jesús <jesusl.temez at gmail.com>:
> Trying to install 2.8.2-1 on a Mac (10.9.5) I find this error:
> Dyld Error Message:
>   Library not loaded: /Library/Frameworks/PROJ.framework/Versions/4/PROJ
>   Referenced from: /Applications/QGIS.app/Contents/MacOS/QGIS
>   Reason: Incompatible library version: QGIS requires version 10.0.0 or
> later, but PROJ provides version 8.0.0
> Binary Images:
>     0x7fff6810f000 -     0x7fff68142817  dyld (239.4)
> <7AD43B9B-5CEA-3C7E-9836-A06909F9CA56> /usr/lib/dyld
>     0x7fff8bc7f000 -     0x7fff8bc7ffff  com.apple.ApplicationServices (48
> 48) <3E3F01A8-314D-378F-835E-9CC4F8820031>
> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Applicat
> ionServices
>     0x7fff8bc9f000 -     0x7fff8bd0bfff  com.apple.framework.IOKit (2.0.1 -
> 907.100.14) <10932113-9F7E-38A0-A158-A019A555CAC3>
> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
>     0x7fff8dd59000 -     0x7fff8df3efff  com.apple.CoreFoundation (6.9 -
> 855.17) <729BD6DA-1F63-3E72-A148-26F21EBF52BB>
> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundatio
> n
> I delete old version first but I can't open new version when finishing the
> installation. I got this message: Qgis can't be open due to a problem.
> Any idea? Thanks
> Jesus
> Qgis-user mailing list
FaunaViva
V.le Sarca 78 - 20125 Milano
Tel: 02 36 59 15 61
Fax: 02 36 59 17 21
Mobile: 331 61 75 136
Email: j.tonetti at faunaviva.it
postacertificata at pec.studiofaunaviva.it
www.faunaviva.it
www.studiofaunaviva.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150519/f18c44c8/attachment.html>
