[Qgis-user] Error installing QGIS 2.8.2-1 on Mac
Jesús jesusl.temez at gmail.com
Tue May 19 15:05:36 PDT 2015
That was!. Thanks a lot.
Jesus
El 19/05/15 22:23, "Jacopo Tonetti" <jacopotonetti at gmail.com> escribió:
> Hi, seems that you have an older version of PROJ library. Did you download the
> package or install via homebrew? I recommend the latter (but you should use
> command line), I followed this
> <https://github.com/OSGeo/homebrew-osgeo4mac/wiki/Developing-on-QGIS-using-OSG
> eo4Mac>   guide and everything is fine, same OS and version of QGIS.
> j
> 2015-05-19 19:38 GMT+02:00 Jesús <jesusl.temez at gmail.com>:
>> Trying to install 2.8.2-1 on a Mac (10.9.5) I find this error:
>> Dyld Error Message:
>>   Library not loaded: /Library/Frameworks/PROJ.framework/Versions/4/PROJ
>>   Referenced from: /Applications/QGIS.app/Contents/MacOS/QGIS
>>   Reason: Incompatible library version: QGIS requires version 10.0.0 or
>> later, but PROJ provides version 8.0.0
>> Binary Images:
>>     0x7fff6810f000 -     0x7fff68142817  dyld (239.4)
>> <7AD43B9B-5CEA-3C7E-9836-A06909F9CA56> /usr/lib/dyld
>>     0x7fff8bc7f000 -     0x7fff8bc7ffff  com.apple.ApplicationServices (48 -
>> 48) <3E3F01A8-314D-378F-835E-9CC4F8820031>
>> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Applicat
>> ionServices
>>     0x7fff8bc9f000 -     0x7fff8bd0bfff  com.apple.framework.IOKit (2.0.1 -
>> 907.100.14) <10932113-9F7E-38A0-A158-A019A555CAC3>
>> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
>>     0x7fff8dd59000 -     0x7fff8df3efff  com.apple.CoreFoundation (6.9 -
>> 855.17) <729BD6DA-1F63-3E72-A148-26F21EBF52BB>
>> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundatio
>> n
>> I delete old version first but I can't open new version when finishing the
>> installation. I got this message: Qgis can't be open due to a problem.
>> Any idea? Thanks
>> Jesus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150520/eaa39fff/attachment.html>
