[Qgis-user] Error installing QGIS 2.8.2-1 on Mac
William Kyngesburye
woklist at kyngchaos.com
Tue May 19 15:32:32 PDT 2015
A general note to all:
You need to make sure to install the latest GDAL Complete - they all may look like the same version (1.11) but they are also dated. PROJ changed recently and QGIS was built after that change, so an old GDAL Complete will break a new QGIS.
I need to add a PROJ version check in the QGIS installer.
On May 19, 2015, at 5:05 PM, Jesús <jesusl.temez at gmail.com> wrote:
> That was!. Thanks a lot.
> Jesus
> El 19/05/15 22:23, "Jacopo Tonetti" <jacopotonetti at gmail.com> escribió:
>> Hi, seems that you have an older version of PROJ library. Did you download the package or install via homebrew? I recommend the latter (but you should use command line), I followed this <https://github.com/OSGeo/homebrew-osgeo4mac/wiki/Developing-on-QGIS-using-OSGeo4Mac> guide and everything is fine, same OS and version of QGIS.
>> j
>> 2015-05-19 19:38 GMT+02:00 Jesús <jesusl.temez at gmail.com>:
>>> Trying to install 2.8.2-1 on a Mac (10.9.5) I find this error:
>>> Dyld Error Message:
>>> Library not loaded: /Library/Frameworks/PROJ.framework/Versions/4/PROJ
>>> Referenced from: /Applications/QGIS.app/Contents/MacOS/QGIS
>>> Reason: Incompatible library version: QGIS requires version 10.0.0 or
>>> later, but PROJ provides version 8.0.0
>>> Binary Images:
>>> 0x7fff6810f000 - 0x7fff68142817 dyld (239.4)
>>> <7AD43B9B-5CEA-3C7E-9836-A06909F9CA56> /usr/lib/dyld
>>> 0x7fff8bc7f000 - 0x7fff8bc7ffff com.apple.ApplicationServices (48 -
>>> 48) <3E3F01A8-314D-378F-835E-9CC4F8820031>
>>> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Applicat
>>> ionServices
>>> 0x7fff8bc9f000 - 0x7fff8bd0bfff com.apple.framework.IOKit (2.0.1 -
>>> 907.100.14) <10932113-9F7E-38A0-A158-A019A555CAC3>
>>> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
>>> 0x7fff8dd59000 - 0x7fff8df3efff com.apple.CoreFoundation (6.9 -
>>> 855.17) <729BD6DA-1F63-3E72-A148-26F21EBF52BB>
>>> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundatio
>>> n
>>> I delete old version first but I can't open new version when finishing the
>>> installation. I got this message: Qgis can't be open due to a problem.
>>> Any idea? Thanks
>>> Jesus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
