[Qgis-user] Shapefile at wrong coordinates
Siki Zoltan siki at agt.bme.hu
Fri May 22 11:37:41 PDT 2015
Dear Barbara,
it is probably a projection issue.
Check the SRS for both layers on both machine and the SRS for the canvas
of QGIS. Are they the same on both machines?
If they match, check the definition of the used SRS in the srs.db on both
machines.
Are they the same?
You can find srs.db in the resource subdirectory of your qgis
installation. srs.db is a sqlite database.
Regards,
Zoltan
On Fri, 22 May 2015, Estevan Barbará wrote:
> Hello guys
> At our lab, we've tried to compare a shapefile of island contours with an
> geotiff of a nautical chart.
> In some of the working stations, the positions were perfectly matched.
> But on one station, the shapes are dislocated nearly 6 miles.
> We've checked the positions in other stations and softwares, and the error
> is only at qgis at this machine.
> How can we solve the problem?
> Regards
> Estevan Barbara
