[Qgis-user] Shapefile at wrong coordinates
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri May 22 12:15:59 PDT 2015
Also you can look at the crs options on the computers. One is probably set up differently then other. Look for the "what do do it the layer has no crs?" On computer is probably set to "use default projection" and the others set to"use project CRS". They should be set to "ask for CRS" in my opinion.
Cheers!
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On May 22, 2015 2:35 PM, "Siki Zoltan [via OSGeo.org]" <ml-node+s1560n5207202h23 at n6.nabble.com> wrote:
> Dear Barbara,
> it is probably a projection issue.
> Check the SRS for both layers on both machine and the SRS for the canvas
> of QGIS. Are they the same on both machines?
> If they match, check the definition of the used SRS in the srs.db on both
> machines.
> Are they the same?
> You can find srs.db in the resource subdirectory of your qgis
> installation. srs.db is a sqlite database.
> Regards,
> Zoltan
> On Fri, 22 May 2015, Estevan Barbará wrote:
> > Hello guys
> > At our lab, we've tried to compare a shapefile of island contours with an
> > geotiff of a nautical chart.
> > In some of the working stations, the positions were perfectly matched.
> > But on one station, the shapes are dislocated nearly 6 miles.
> > We've checked the positions in other stations and softwares, and the error
> > is only at qgis at this machine.
> > How can we solve the problem?
> > Regards
> > Estevan Barbara
> Qgis-user mailing list
> [hidden email]
> ________________________________
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Shapefile-at-wrong-coordinates-tp5207199p5207202.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Shapefile-at-wrong-coordinates-tp5207199p5207208.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150522/d05acb5a/attachment.html>
