[Qgis-user] How to assign geographical objects to records and find records that have no geographical object
James Keener
jim at jimkeener.com
Wed May 27 05:43:53 PDT 2015
If you can't get record order to be the same, you can assign each an id and join on it.
I haven't yet attempted to copy-paste attributes between tables. You may have to add the expected columns to the destination shapefile though.
I'm not at a computer at the moment, but I wonder if there is a plugin to help with this. (Or how hard it'd be to write one?)
Jim
On May 27, 2015 8:40:12 AM EDT, Randal Hale <rjhale at northrivergeographic.com> wrote:
>One way to go about doing it is to make a shapefile and place a point.
>Make sure that point has an attribute that relates to your table.
> * You table has a record field so your shapefile has a record field.
> * record 1 corresponds to point 1
>If you add data to QGIS and Right click on it (in the layers window)
>you
>can open the properties. From there you can Join (7 menu items down on
>the left) data together.
>I hope that helps some.
>Randy
>On 05/27/2015 07:51 AM, Jens Verwaerde wrote:
>> I've imported a table with records and would like to add geographical
>> points to the records.
>> In Mapinfo, one can have the table data open and the map and click on
>> a record (in the table) and afterwards on a location in the map, so
>> that a geographical object (a point) is "attached" to the record.
>> Afterwards, it is quite easy to look for records that haven't yet
>have
>> any geographical objects attached to them.
>> 1 -- how can I interactively assign geographical objects to a record
>> table in qgis
>> 2 -- how can I look for records in the table that do not yet have
>> related geographical objects?
>> /Jens Verwaerde/
>> Biologist
>> Natuurpunt
>> www.natuurpunt.be <http://www.natuurpunt.be>
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>Randal Hale
>North River Geographic Systems, Inc
>http://www.northrivergeographic.com
>423.653.3611 rjhale at northrivergeographic.com
>twitter:rjhale http://about.me/rjhale
>http://www.northrivergeographic.com/introduction-to-quantum-gis
>Southeast OSGEO: http://wiki.osgeo.org/wiki/Southeast_US
Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150527/78a1c61d/attachment.html>
