[Qgis-user] CRS problems in QGIS
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Wed May 27 12:49:41 PDT 2015
I would be happy to help out if you send me the files.  But start by looking at the .prj file created with the .shp file.  Is there one?  If you open the .prj file (use notepad), are they correct?  Try right clicking on a layer and manually define the CRS them zoom to the layer extent. Has it moved?  Look at the defaults option to see what do do when a file has no CRS (bellow the on the fly option).  Select "ask".  If that fails, send the files to Nicolas.Cadieux at Archeotec.ca.
Or you can just open your kml files in google Qgis and save then as .shp!
Cheers
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On May 27, 2015 14:17, "Ferry van den Oever [via OSGeo.org]	" <ml-node+s1560n5207867h38 at n6.nabble.com> wrote: Hello, I use QGIS Chugiak 2.4.0. I want to import 2 dxf-files. I use the dxf2shp-plugin. But both dxf files are in different coordinate systems (resp. Dutch RD & Belgian Lambert72). The location of the drawings is be the same, but whenever I import both dxf-files there are many kilometers between them? Of course, 'on-the-fly-projection 'is on. One dxf consists of points, the other one of polylines. What am I doing wrong? The dxf-files themselves are correct. If I save them as a KML-files and import them in Google Earth, they are spot on on the same, exact location. ?? best regards Ferry     Ps:of course I’m willing to send the named files in question. If anyone is challenged ;-) With best regards Ferry van den Oever Specialist non-destructief onderzoek 06-101 533 76 Saricon Postbus 92 3360 AB Sliedrecht +31 (0) 184-422538 www.saricon.nl     _______________________________________________
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/CRS-problems-in-QGIS-tp5207867.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/CRS-problems-in-QGIS-tp5207867p5207873.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150527/064cc1fc/attachment.html>
