[Qgis-user] CRS problems in QGIS
Andreas Neumann a.neumann at carto.net
Wed May 27 13:46:44 PDT 2015
Hi Ferry,
As far as I know, DXF files do not contain projection information. Did
you assign the projection information by hand? Or how does QGIS know
what projection your DXF files are based on?
Andreas
On 27.05.2015 20:05, Ferry van den Oever wrote:
> Saricon - Safety & Risk Consultancy
> Hello, I use QGIS Chugiak 2.4.0.
> I want to import 2 dxf-files. I use the dxf2shp-plugin. But both dxf
> files are in different coordinate systems (resp. Dutch RD & Belgian
> Lambert72). The location of the drawings is be the same, but whenever
> I import both dxf-files there are many kilometers between them? Of
> course, 'on-the-fly-projection 'is on.
> One dxf consists of points, the other one of polylines.
> What am I doing wrong?
> The dxf-files themselves are correct. If I save them as a KML-files
> and import them in Google Earth, they are spot on on the same, exact
> location.
> best regards
> Ferry
> Ps:of course I’m willing to send the named files in question. If
> anyone is challenged ;-)
> With best regards
> Ferry van den Oever
> Specialist non-destructief onderzoek
> 06-101 533 76
> Saricon
> Postbus 92
> 3360 AB Sliedrecht
> +31 (0) 184-422538
> www.saricon.nl <http://www.saricon.nl>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150527/0fb96fa4/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150527/0fb96fa4/attachment.png>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150527/0fb96fa4/attachment.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150527/0fb96fa4/attachment-0001.jpe>
