[Qgis-user] CRS problems in QGIS
Richard Duivenvoorde rdmailings at duif.net
Wed May 27 23:36:16 PDT 2015
On 27-05-15 22:46, Andreas Neumann wrote:
> Hi Ferry,
> As far as I know, DXF files do not contain projection information. Did
> you assign the projection information by hand? Or how does QGIS know
> what projection your DXF files are based on?
1) you set your project to the desired projection
2) enable OTF
3) set every layer to the right projection
done :-)
Regards,
