[Qgis-user] reclassify with tab
Eugenio Trumpy frippe12573 at hotmail.com
Thu May 28 00:18:50 PDT 2015
Hi everybody,
I'm using QGIS 2.9.0-master version 13d67c0,
and I'm trying to build a model to process some maps.
Among the operations in the model I have to use a raster reclassify function
many times with different tabs of values.
I have already set the reclassify operation by using the saga module, named 'Reclassify',
however this module lost the values defined in the table. Only using such module alone it works.
So I wonder if there is a way to fix the table for this module in the model builder or if the only solution
is to use the grass module, r.reclass?
Thanks for your feedback...
Eugenio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150528/f7a048a7/attachment.html>
