[Qgis-user] different QGIS behavior between windows and lubuntu
Giacomo Fontanelli giacomofontanelli76 at gmail.com
Fri May 29 01:20:05 PDT 2015
I used to work with qgis 2.8.1 in Lubuntu and in windows7.
Each time I try to multiplicate a map for a number comprise between 0 and 1
(i.e. 0.1) I get a good results on windows OS, but I get a map with only 0
and NaN on Linux.
Further, I get a correct result on Lubuntu if I divide by 10 instead of
multiplicate by 0.1.
Conclusion
"band at map" * 0.1 on windows = OK "band at map" * 0.1 on lubuntu = only 0 and
NaN "band at map" / 10 on lubuntu = ok.
I use the same gdal version and I always get a correct Float32 map.
Canyou help me?
Thanx
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150529/15563ec5/attachment.html>
