[Qgis-user] different QGIS behavior between windows and lubuntu
Goyo goyodiaz at gmail.com
Fri May 29 10:09:51 PDT 2015
FWIW I tried in master and it works so far (ubuntu 15.04).
Goyo
2015-05-29 10:20 GMT+02:00 Giacomo Fontanelli <giacomofontanelli76 at gmail.com>:
> I used to work with qgis 2.8.1 in Lubuntu and in windows7.
> Each time I try to multiplicate a map for a number comprise between 0 and 1
> (i.e. 0.1) I get a good results on windows OS, but I get a map with only 0
> and NaN on Linux.
> Further, I get a correct result on Lubuntu if I divide by 10 instead of
> multiplicate by 0.1.
> Conclusion
> "band at map" * 0.1 on windows = OK "band at map" * 0.1 on lubuntu = only 0 and
> NaN "band at map" / 10 on lubuntu = ok.
> I use the same gdal version and I always get a correct Float32 map.
> Canyou help me?
> Thanx
> Qgis-user mailing list
