[Qgis-user] different QGIS behavior between windows and lubuntu
George Silva georger.silva at gmail.com
Fri May 29 12:22:53 PDT 2015
It looks like this bug:
http://hub.qgis.org/issues/12450
Add some traction to the ticket :D.
On Fri, May 29, 2015 at 2:09 PM, Goyo <goyodiaz at gmail.com> wrote:
> FWIW I tried in master and it works so far (ubuntu 15.04).
> Goyo
> 2015-05-29 10:20 GMT+02:00 Giacomo Fontanelli <
> giacomofontanelli76 at gmail.com>:
> > I used to work with qgis 2.8.1 in Lubuntu and in windows7.
> > Each time I try to multiplicate a map for a number comprise between 0
> and 1
> > (i.e. 0.1) I get a good results on windows OS, but I get a map with only
> 0
> > and NaN on Linux.
> > Further, I get a correct result on Lubuntu if I divide by 10 instead of
> > multiplicate by 0.1.
> > Conclusion
> > "band at map" * 0.1 on windows = OK "band at map" * 0.1 on lubuntu = only 0
> and
> > NaN "band at map" / 10 on lubuntu = ok.
> > I use the same gdal version and I always get a correct Float32 map.
> > Canyou help me?
> > Thanx
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
George R. C. Silva
Sigma Geosistemas LTDA
http://www.sigmageosistemas.com.br/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150529/929111b1/attachment.html>
