[Qgis-user] different QGIS behavior between windows and lubuntu
Fernando M. Roxo da Motta petro at roxo.org
Fri May 29 12:27:06 PDT 2015
On Fri, 29 May 2015 10:20:05 +0200, Giacomo Fontanelli
<giacomofontanelli76 at gmail.com> wrote:
> I used to work with qgis 2.8.1 in Lubuntu and in windows7.
> Each time I try to multiplicate a map for a number comprise between 0
> and 1 (i.e. 0.1) I get a good results on windows OS, but I get a map
> with only 0 and NaN on Linux.
> Further, I get a correct result on Lubuntu if I divide by 10 instead
> of multiplicate by 0.1.
  It looks very much like a localization problem.  I guess that with
this name you are using a platform with Italian language.   I think
that the standard there is the same I have in Brazil, that is the
decimal separator is comma (,) instead of dot (.).   Try to use:
   "band at map" * 0,1
  Hope this helps.
> Conclusion
> "band at map" * 0.1 on windows = OK "band at map" * 0.1 on lubuntu = only 0
> and NaN "band at map" / 10 on lubuntu = ok.
> I use the same gdal version and I always get a correct Float32 map.
> Canyou help me?
> Thanx
  Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
Except where explicitly stated I speak on my own behalf.|  VI !!
      ( Usuário Linux registrado #39505 )               | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
