[Qgis-user] QGIS 2.8.2 no values calculating area with Export/Add Geometry Columns on Ellipsoid
ralfwessels
gis at ralf-wessels.de
Sat May 30 05:04:06 PDT 2015
Hi all,
I tested the area calculating functions in QGIS 2.8.2 and figured out, that
I just get zero values when using the function Vector > Geometry Tools >
Export/Add Geometry Columns calculating on Ellipsoid.
I tested it with shape-files and PostGIS-Layers with the QGIS Windows
Installer Version 64bit.
I suppose this is a bug in version 2.8.2 because it works in 2.6
In 2.8.2 it also works when calculating on Layer CRS or Project CRS, but not
on Ellipsoid.
Can someone reproduce this error?
Another strange thing when using the Export/Add Geometry Columns - function
ist the message (see screenshot) I always get when click OK to execute the
function.
<http://osgeo-org.1560.x6.nabble.com/file/n5208252/screen_warning.jpg>
Is this warning normal? I don't have the layers attribute table open.
Best greetings from Berlin
Ralf
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-2-8-2-no-values-calculating-area-with-Export-Add-Geometry-Columns-on-Ellipsoid-tp5208252.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
