[Qgis-user] matching .prj (ArcGIS) with CRS in QGIS
Andre Joost andre+joost at nurfuerspam.de
Sun May 31 07:00:07 PDT 2015
Am 30.05.2015 um 23:31 schrieb Nicolas Cadieux:
> Hi,
> I am assuming QGIS cannot read this projection?
You are right, the projection name is not known for QGIS.
The WKT string for Kertau RSO is:
PROJCS["Kertau (RSO) / RSO Malaya (m)",
     GEOGCS["Kertau (RSO)",
         DATUM["Kertau_RSO",
             SPHEROID["Everest 1830 (RSO 1969)",6377295.664,300.8017,
                 AUTHORITY["EPSG","7056"]],
             AUTHORITY["EPSG","6751"]],
         PRIMEM["Greenwich",0,
             AUTHORITY["EPSG","8901"]],
         UNIT["degree",0.0174532925199433,
             AUTHORITY["EPSG","9122"]],
         AUTHORITY["EPSG","4751"]],
     PROJECTION["Hotine_Oblique_Mercator"],
     PARAMETER["latitude_of_center",4],
     PARAMETER["longitude_of_center",102.25],
     PARAMETER["azimuth",323.0257905],
     PARAMETER["rectified_grid_angle",323.1301023611111],
     PARAMETER["scale_factor",0.99984],
     PARAMETER["false_easting",804670.24],
     PARAMETER["false_northing",0],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]],
     AXIS["Easting",EAST],
     AXIS["Northing",NORTH],
     AUTHORITY["EPSG","3168"]]
which looks similar to the one given, but the ellipsoid major axis is
different, and False Easting.
For the different namings of the projection, see
https://trac.osgeo.org/gdal/ticket/2745
http://lists.maptools.org/pipermail/proj/2010-September/005349.html
HTH,
André Joost
