[Qgis-user] matching .prj (ArcGIS) with CRS in QGIS
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sun May 31 08:13:14 PDT 2015
I have done this in the past using documents found here. Qgis uses proj.4 syntax.
http://ie.unc.edu/cempd/projects/mims/spatial_beta/external/PROJ4.html
You can create user defined projection in "Setting/custom CRS".
Good luck!
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On May 31, 2015 10:30 AM, "K Imran M [via OSGeo.org]" <ml-node+s1560n5208316h57 at n6.nabble.com> wrote:
	Dear Andre, Is it possible, because of the different WKT string specification, my shape files was misaligned for about 200 meters to 300 meters when I chose Kertau (RSO)/RSO Malaya (m) (EPSG:3168) as the projection (OTF)? In view of that issue, can you advise me if I  1) can I still use the Kertau (RSO)/RSO Malaya (m) (EPSG:3168) projection? Or 2) should I transform the projection to any other projection? Or 3) should I use the User-define CRS? If yes, how can I do that? I apologize for any trivial questions here. Your responses is very much appreciated. Thanks and best wishes, Kamarul On Sun, May 31, 2015 at 10:00 PM, Andre Joost < [hidden email] > wrote: <blockquote style="border-left:2px solid #cccccc;padding:0 1em" style="margin:0 0 0 0.8ex;border-left:1px #ccc solid;padding-left:1ex">Am 30.05.2015 um 23:31 schrieb Nicolas Cadieux:
I am assuming QGIS cannot read this projection?
You are right, the projection name is not known for QGIS.
The WKT string for Kertau RSO is:
PROJCS["Kertau (RSO) / RSO Malaya (m)",
    GEOGCS["Kertau (RSO)",
        DATUM["Kertau_RSO",
            SPHEROID["Everest 1830 (RSO 1969)",6377295.664,300.8017,
                AUTHORITY["EPSG","7056"]],
            AUTHORITY["EPSG","6751"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4751"]],
    PROJECTION["Hotine_Oblique_Mercator"],
    PARAMETER["latitude_of_center",4],
    PARAMETER["longitude_of_center",102.25],
    PARAMETER["azimuth",323.0257905],
    PARAMETER["rectified_grid_angle",323.1301023611111],
    PARAMETER["scale_factor",0.99984],
    PARAMETER["false_easting",804670.24],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH],
    AUTHORITY["EPSG","3168"]]
which looks similar to the one given, but the ellipsoid major axis is different, and False Easting.
For the different namings of the projection, see
https://trac.osgeo.org/gdal/ticket/2745
http://lists.maptools.org/pipermail/proj/2010-September/005349.html
HTH,
André Joost
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
-- Dr. Kamarul Imran Musa, M.D. M.Community.Med. Associate Professor (Epidemiology and Biostatistics) &  Public Health Physician Dept of Community Medicine School of Medical Sciences 16150 Universiti Sains Malaysia, Kbg Kerian Kelantan Thomson Reuters researchID:  http://www.researcherid.com/rid/G-4864-2010 Google-scholar:  http://scholar.google.co.uk/citations?user=aZyayMgAAAAJ&hl=en&authuser=1 blog:  http://designdataanalysis.wordpress.com     email :  [hidden email]  ,  [hidden email]
[hidden email]
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/matching-prj-ArcGIS-with-CRS-in-QGIS-tp5208259p5208316.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/matching-prj-ArcGIS-with-CRS-in-QGIS-tp5208259p5208323.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150531/a9411854/attachment.html>
