[Qgis-user] Python Script, Layer is not valid
nicolas.cadieux at archeotec.ca nicolas.cadieux at archeotec.ca
Tue Nov 3 13:22:30 PST 2015
I am writing a small python script to use in a stand alone application.
It is the first time I use the QGIS API in Python.  I can't seem to be
able to open a Shape file using QGIS through Python.  The following
script returns a "layer is not valid".  I can open the layer from the
QGIS Python console and i is valid.  I just can't do it from Python
2.7.  Since I can import the qgis.core and others, I am assuming that my
Python installation and path's are ok.  I am using Eclipse configured as
explained in the latest Cookbook (as best as I could).  (I am stating
Eclipse with the .bat file).
For now, I will use Fiona to open the shape file but I would like to go
with the QGIS API.  Can anyone help?
Thanks!
Nicolas
from qgis.gui import *
from qgis.utils import*
from qgis.core import *
QgsApplication.setPrefixPath("C:/OSGeo4W64/apps/qgis", True)
app = QgsApplication([], True)
QgsApplication.initQgis()
layer =
QgsVectorLayer('c:/pytemp/PhD_Limite_Exterieur_Sol_et_Veg_151029.shp',
'shpFilter', 'ogr')
if layer.isValid():
     print 'layer is valid'
else:
     print 'layer is not valid'
