[Qgis-user] Psuedo-color raster legends
Fernando M. Roxo da Motta petro at roxo.org
Wed Nov 4 10:47:03 PST 2015
On Wed, 04 Nov 2015 18:44:15 +0200, Benoit de Cabissole
<benoit-3 at bc-consult.com> wrote:
> Hi Robin,
> Just released version 0.9.1 to fix Fernando's error report.
  Hi all,
  Benoit, just to let you know, I have tested the fix and it worked as
expected.
> Your point 1: in theory yes; but I'm personally do not feel at ease
> contributing to such a repository. I rather have my plugins in our own
> repository: 1, because they serve well our purposes but, perhaps, not
> so well the QGIS community at large, and 2, they mostly do not follow
> the programming philosophy of QGIS (they are developed on the spur of
> the moment and are not good examples of code!).
  Ok, I did nit verified the code if it meet or not the Qgis standard,
but I bet to differ about attending to the comunity at large.  This is
indeed a very useful plugin and I have used it since its early
incantation, and was missing it after it stopped to work.
  I thank you very much for this plugin and for your attention to my
report.  If I could incentive you to contribute I think it would be
very nice.
  Best regards.
> Your point 2: well the design of the interface has to be tweaked to
> display correctly on your system. I will see what I can do about
> that... Are you in a position to test the ui on your Mac?
> Your point 3: why not, but a proper developer should be assigned to
> the plugin. As far as I understand it, core plugins are in their own
> active branch in the QGIS source tree and are maintained by their
> creator or dedicated developers. Unfortunately, I have strictly no
> experience with the GIT world!
> Regards,
> Benoit
> On 04/11/2015 18:12, Robin Wilson wrote:
> > On 4 Nov 2015, at 15:44, Fernando M. Roxo da Motta <petro at roxo.org>
> > wrote:
> > Hi Robin,
> > Regarding your point 1 below, please see the latest version (0.9.0)
> > of "Color Scale Bar for One-Band Rasters" (bccscbar) at
> > http://www.bc-consult.com/free/bccscbar.html [1] [3]. It is now
> > possible to use the currently selected raster from the Layers
> > panel. I think this is a very interesting tool to have available. I
> > downloaded the last available version from that site and installed
> > in my computer, a Xubuntu 14.0 64 bits running Qgis 2.12. When I
> > opened the plugin manager and activated it I could find it under
> > "raster" menu, as described. I closed Qgis and opened it again, and
> > I got the following:
> > =================8<--------------------------
> > Couldn't load plugin bccscbar due to an error when calling its
> > classFactory() method
> Hi Benoit,
> Thanks so much for releasing an updated version - I wasn't aware the
> plugin was under active development!
> I've got a few questions and pieces of feedback:
> 1. Would it be possible to add it to the standard plugins repository,
> so that it is easier for users to install?
> 2. The dialog doesn't display quite correctly on my system (OS X,
> running QGIS 2.10) - see
> https://www.dropbox.com/s/8wwgsm21ze854vc/ColorBarDialog.png?dl=0 [3].
> Do you have any idea what might be causing this?
> 3. Would you be interested in this being integrated into core QGIS?
> Best regards - and thanks for the plugin,
> Robin
> Qgis-user mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
> Links:
> [1] http://www.bc-consult.com/free/bccscbar.html
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [3] https://www.dropbox.com/s/8wwgsm21ze854vc/ColorBarDialog.png?dl=0
  Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
Except where explicitly stated I speak on my own behalf.|  VI !!
      ( Usuário Linux registrado #39505 )               | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
