[Qgis-user] Psuedo-color raster legends
Paulo van Breugel
p.vanbreugel at gmail.com
Wed Nov 4 11:01:11 PST 2015
On Wed, Nov 4, 2015 at 7:47 PM, Fernando M. Roxo da Motta <petro at roxo.org>
wrote:
> On Wed, 04 Nov 2015 18:44:15 +0200, Benoit de Cabissole
> <benoit-3 at bc-consult.com> wrote:
> > Hi Robin,
> > Just released version 0.9.1 to fix Fernando's error report.
> Hi all,
> Benoit, just to let you know, I have tested the fix and it worked as
> expected.
> > Your point 1: in theory yes; but I'm personally do not feel at ease
> > contributing to such a repository. I rather have my plugins in our own
> > repository: 1, because they serve well our purposes but, perhaps, not
> > so well the QGIS community at large, and 2, they mostly do not follow
> > the programming philosophy of QGIS (they are developed on the spur of
> > the moment and are not good examples of code!).
> Ok, I did nit verified the code if it meet or not the Qgis standard,
> but I bet to differ about attending to the comunity at large. This is
> indeed a very useful plugin and I have used it since its early
> incantation, and was missing it after it stopped to work.
+1 Just to chime in on the usefulness of the addon for the QGIS community -
I think it certainly is. I had used it in the past, and I am happy to hear
it is working again.
> I thank you very much for this plugin and for your attention to my
> report. If I could incentive you to contribute I think it would be
> very nice.
> Best regards.
> > Your point 2: well the design of the interface has to be tweaked to
> > display correctly on your system. I will see what I can do about
> > that... Are you in a position to test the ui on your Mac?
> > Your point 3: why not, but a proper developer should be assigned to
> > the plugin. As far as I understand it, core plugins are in their own
> > active branch in the QGIS source tree and are maintained by their
> > creator or dedicated developers. Unfortunately, I have strictly no
> > experience with the GIT world!
> > Regards,
> > Benoit
> > On 04/11/2015 18:12, Robin Wilson wrote:
> > > On 4 Nov 2015, at 15:44, Fernando M. Roxo da Motta <petro at roxo.org>
> > > wrote:
> > > Hi Robin,
> > > Regarding your point 1 below, please see the latest version (0.9.0)
> > > of "Color Scale Bar for One-Band Rasters" (bccscbar) at
> > > http://www.bc-consult.com/free/bccscbar.html [1] [3]. It is now
> > > possible to use the currently selected raster from the Layers
> > > panel. I think this is a very interesting tool to have available. I
> > > downloaded the last available version from that site and installed
> > > in my computer, a Xubuntu 14.0 64 bits running Qgis 2.12. When I
> > > opened the plugin manager and activated it I could find it under
> > > "raster" menu, as described. I closed Qgis and opened it again, and
> > > I got the following:
> > > =================8<--------------------------
> > > Couldn't load plugin bccscbar due to an error when calling its
> > > classFactory() method
> > Hi Benoit,
> > Thanks so much for releasing an updated version - I wasn't aware the
> > plugin was under active development!
> > I've got a few questions and pieces of feedback:
> > 1. Would it be possible to add it to the standard plugins repository,
> > so that it is easier for users to install?
> > 2. The dialog doesn't display quite correctly on my system (OS X,
> > running QGIS 2.10) - see
> > https://www.dropbox.com/s/8wwgsm21ze854vc/ColorBarDialog.png?dl=0 [3].
> > Do you have any idea what might be causing this?
> > 3. Would you be interested in this being integrated into core QGIS?
> > Best regards - and thanks for the plugin,
> > Robin
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
> > Links:
> > [1] http://www.bc-consult.com/free/bccscbar.html
> > [2] http://lists.osgeo.org/mailman/listinfo/qgis-user
> > [3] https://www.dropbox.com/s/8wwgsm21ze854vc/ColorBarDialog.png?dl=0
> Roxo
> ---------------- Non luctari, ludare -------------------+ WYSIWYG
> Fernando M. Roxo da Motta <petro at roxo.org> | Editor?
> Except where explicitly stated I speak on my own behalf.| VI !!
> ( Usuário Linux registrado #39505 ) | I see text,
> ------------ Quis custodiet ipsos custodes?-------------+ I get text!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151104/e5969ea2/attachment.html>
