[Qgis-user] Zooming in to a map area
J.O. Williams j.o.williams.jow at gmail.com
Fri Nov 6 14:50:05 PST 2015
Greetings,
I have noticed this problem too.  In my case, it was southern Texas (and
have seen it SW Colorado).  I assumed it was due to limitations in an
API.  I could go down to 1:2001 but not do 1:2000.
Thanks,
J.O. Williams
On 11/06/2015 11:59 AM, Neumann, Andreas wrote:
> Hi,
> This sounds like you have a plugin installed/enabled that forces QGIS
> into certain zoom levels. I think it is the "Tile Map Scale Plugin" or
> something similar. Disable this plugin and try again.
> Greetings,
> Andreas
> On 2015-11-06 19:17, Keith Burr wrote:
>> I am having a problem with zooming in.  When I try to zoom in I can
>> only go to 1:2,256 and no closer.  I am sure it is some setting that
>> I need to change.
>> but I don't know what to do to make it work to zoom in closer.
>> Any help would be appriciated.
>> Thanks,
>>     Keith
>> * Keith Burr, Survey Technician - kburr at marshandlegge.com
>> <mailto:kburr at marshandlegge.com>**
>> <http://www.marshandlegge.com/>
>>  560 North Loudoun Street
>>  Winchester, VA 22601
>>  Phone: 540-667-0468
>>  Fax: 540-667-0469*
>> avast! Antivirus: Outbound message clean.
>> Virus Database (VPS): 151027-1, 10/27/2015
>> Tested on: 11/6/2015 1:18:01 PM
>> avast! - copyright (c) 1988-2015 AVAST Software.
>> https://www.avast.com/antivirus
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151106/a35e6a1d/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151106/a35e6a1d/attachment.jpe>
