[Qgis-user] pyqgis load error
Matthias Kuhn matthias at opengis.ch
Tue Nov 10 02:12:06 PST 2015
Hi Eugenio,
Are you experienced enough with git to cherry-pick another commit and
check if that fixes your issue?
https://github.com/m-kuhn/QGIS/commit/d4b30c3e2c8334d4576bb7de4f2859f4827365e0
Regards,
Matthias
On 11/10/2015 10:54 AM, Eugenio Trumpy wrote:
> Hi everybody,
> this morning I decided to compile qgis on my ubuntu 15.10 due to the fact
> that the version I had: 2.13.0-master - 2bb0cf9, had problem with
> grass process.
> So I update the code & ccmake && make && make install, I had no errors
> but launching
> qgis I have the error:
> Couldn't load PyQGIS.
> Python support will be disabled.
> getvalue() did not return a string
> Python version:
> 2.7.10 (default, Oct 14 2015, 16:09:02)
> [GCC 5.2.1 20151010]
> QGIS version:
> 2.13.0-Master 'Master', 452e61c
> Python path:
> ['/usr/local/share/qgis/python', u'/home/eugenio/.qgis2/python',
> u'/home/eugenio/.qgis2/python/plugins',
> '/usr/local/share/qgis/python/plugins', '/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-x86_64-linux-gnu',
> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PILcompat',
> '/usr/lib/python2.7/dist-packages/gtk-2.0',
> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> '/usr/lib/python2.7/dist-packages/wx-3.0-gtk2']
> Any hints on how to solve this problem?
> best
> Eugenio
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Help to improve QGIS rendering possibilities before Nov 30, 2015
http://www.opengis.ch/2015/11/02/qgis-crowdfunding-2-5d-rendering
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151110/806ef4de/attachment.html>
