[Qgis-user] pyqgis load error
Eugenio Trumpy frippe12573 at hotmail.com
Wed Nov 11 04:59:03 PST 2015
Hi all,
I solved the problem here below, deleting the building directory,
even if I performed make clean. I guess it was not enough.
best
E.
> > > On 11/10/2015 10:54 AM, Eugenio Trumpy wrote:
> > > > Hi everybody,
> > > > this morning I decided to compile qgis on my ubuntu 15.10 due to
> > the fact
> > > > that the version I had: 2.13.0-master - 2bb0cf9, had problem with
> > > > grass process.
> > > > So I update the code & ccmake && make && make install, I had no errors
> > > > but launching
> > > > qgis I have the error:
> > > > Couldn't load PyQGIS.
> > > > Python support will be disabled.
> > > > getvalue() did not return a string
> > > > Python version:
> > > > 2.7.10 (default, Oct 14 2015, 16:09:02)
> > > > [GCC 5.2.1 20151010]
> > > > QGIS version:
> > > > 2.13.0-Master 'Master', 452e61c
> > > > Python path:
> > > > ['/usr/local/share/qgis/python', u'/home/eugenio/.qgis2/python',
> > > > u'/home/eugenio/.qgis2/python/plugins',
> > > > '/usr/local/share/qgis/python/plugins', '/usr/lib/python2.7',
> > > > '/usr/lib/python2.7/plat-x86_64-linux-gnu',
> > > > '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> > > > '/usr/lib/python2.7/lib-dynload',
> > > > '/usr/local/lib/python2.7/dist-packages',
> > > > '/usr/lib/python2.7/dist-packages',
> > > > '/usr/lib/python2.7/dist-packages/PILcompat',
> > > > '/usr/lib/python2.7/dist-packages/gtk-2.0',
> > > > '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> > > > '/usr/lib/python2.7/dist-packages/wx-3.0-gtk2']
> > > > Any hints on how to solve this problem?
> > > > best
> > > > Eugenio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151111/cf4e84fd/attachment.html>
