[Qgis-user] Load ESRI Personal Geodatabase in QGIS 2.8.1
Randal Hale
rjhale at northrivergeographic.com
Tue Nov 17 06:42:22 PST 2015
I worked my way through this in 2.8.x -
I did this on a 64 bit windows install - I had it working. The person I
was attempting to help couldn't get it to work following my directions -
so - proceed at your own risk:
http://www.northrivergeographic.com/qgis-accessing-personal-geodatabase
Randy
On 11/17/2015 09:24 AM, Burghardt.Scholle at stadt.wolfsburg.de wrote:
> Hi Ulrike,
> yes, it is possible to open a pGDB in QGIS. However, the versions of
> QGIS and MS Access must be the same: 32bit QGIS = 32bit Access vs.
> QGIS 64bit = 64bit MS Access.
> Greetings
> Burghardt
> *Von:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *Im Auftrag
> von *Ulrike Assmann
> *Gesendet:* Dienstag, 17. November 2015 09:56
> *An:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> *Cc:* bs at hstumwelt.de <mailto:bs at hstumwelt.de>
> *Betreff:* [Qgis-user] Load ESRI Personal Geodatabase in QGIS 2.8.1
> Dear list,
> I have a problem with opening a ESRI Personal Geodatabase with
> Annotation Layers in QGIS 2.8.1. I have tried to open it as vector layer:
> • as "Datei/file" using "MDB" and also
> • as "Datenbank/database" using type
> "ESRI-Personal-GeoDatabase", Might I have chosen an incorrect database
> connection? How do I fill the entry mask properly to make it work?
> I got the following error messages:
> • first message: "ungültige Datenquelle/invalid data source"
> • second message: "Verbindung fehlgeschlagen/connection failed".
> Is there even the possibility to open a ESRI Personal Geodatabase in QGIS?
> Many thanks
> Ulrike
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
North River Geographic Systems, Inc
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
http://www.northrivergeographic.com/introduction-to-quantum-gis
Southeast OSGEO: http://wiki.osgeo.org/wiki/Southeast_US
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151117/1694da57/attachment.html>
