[Qgis-user] Load ESRI Personal Geodatabase in QGIS 2.8.1
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Tue Nov 17 06:34:44 PST 2015
Hi there,
There is a work-around to load 32-bit gdb files with QGIS 64-bit. You need
to install MS Office 64-bit patch for Access.
Regards,
Saber
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of
Burghardt.Scholle at stadt.wolfsburg.de
Sent: 17 November 2015 14:25
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Load ESRI Personal Geodatabase in QGIS 2.8.1
Hi Ulrike,
yes, it is possible to open a pGDB in QGIS. However, the versions of QGIS
and MS Access must be the same: 32bit QGIS = 32bit Access vs. QGIS 64bit =
64bit MS Access.
Greetings
Burghardt
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von
Ulrike Assmann
Gesendet: Dienstag, 17. November 2015 09:56
An: qgis-user at lists.osgeo.org
Cc: bs at hstumwelt.de
Betreff: [Qgis-user] Load ESRI Personal Geodatabase in QGIS 2.8.1
Dear list,
I have a problem with opening a ESRI Personal Geodatabase with Annotation
Layers in QGIS 2.8.1. I have tried to open it as vector layer:
as "Datei/file" using "MDB" and also
as "Datenbank/database" using type "ESRI-Personal-GeoDatabase",
Might I have chosen an incorrect database connection? How do I fill the
entry mask properly to make it work?
I got the following error messages:
first message: "ungültige Datenquelle/invalid data source"
second message: "Verbindung fehlgeschlagen/connection failed".
Is there even the possibility to open a ESRI Personal Geodatabase in QGIS?
Many thanks
Ulrike
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell pro
ducts, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151117/8a58a55e/attachment.html>
