[Qgis-user] Load ESRI Personal Geodatabase in QGIS 2.8.1
Burghardt.Scholle at stadt.wolfsburg.de Burghardt.Scholle at stadt.wolfsburg.de
Tue Nov 17 06:24:50 PST 2015
Hi Ulrike,
yes, it is possible to open a pGDB in QGIS. However, the versions of QGIS and MS Access must be the same: 32bit QGIS = 32bit Access vs. QGIS 64bit = 64bit MS Access.
Greetings
Burghardt
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Ulrike Assmann
Gesendet: Dienstag, 17. November 2015 09:56
An: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Cc: bs at hstumwelt.de<mailto:bs at hstumwelt.de>
Betreff: [Qgis-user] Load ESRI Personal Geodatabase in QGIS 2.8.1
Dear list,
I have a problem with opening a ESRI Personal Geodatabase with Annotation Layers in QGIS 2.8.1. I have tried to open it as vector layer:
*          as "Datei/file" using "MDB" and also
*          as "Datenbank/database" using type "ESRI-Personal-GeoDatabase", Might I have chosen an incorrect database connection? How do I fill the entry mask properly to make it work?
I got the following error messages:
*          first message: "ungültige Datenquelle/invalid data source"
*          second message: "Verbindung fehlgeschlagen/connection failed".
Is there even the possibility to open a ESRI Personal Geodatabase in QGIS?
Many thanks
Ulrike
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151117/953d5edf/attachment.html>
