[Qgis-user] Print composer/Atlas
Kåre Mølgaard Rasmussen Kare.Molgaard.Rasmussen at randers.dk
Mon Nov 23 03:55:25 PST 2015
Hi Alexandre and Joris
Thanks for your replies on my Atlas issue. I´ll try Alexandres approach.
Regards
Kaare
Fra: Alexandre Neto [mailto:senhor.neto at gmail.com]
Sendt: 23. november 2015 11:29
Til: Kåre Mølgaard Rasmussen; qgis-user at lists.osgeo.org
Cc: Mie Mølbak
Emne: Re: [Qgis-user] Print composer/Atlas
Hello Kaare,
As far as I know, the answer is no. Atlas won't split (or union) features for you. So probably you would have to deal with two atlas projects, one to create the onwers resume page. And other to create the individual parcels by owner, by converting the multipolygons into polygons.
Postgis may be handy in this case.
Also, if you choose descritive names for your output files, maybe you can make a script to join the owners page with the indivual pages.
Alexandre Neto
Kåre Mølgaard Rasmussen <Kare.Molgaard.Rasmussen at randers.dk<mailto:Kare.Molgaard.Rasmussen at randers.dk>> escreveu no dia sex, 20/11/2015 às 12:35:
Hi QGIS-Users
We´re currently trying to use the Atlas function for the following purpose:
We want to create a PDF-letter containing some standard text and one/more map(s) for each of the parcels, that a specific owner has.
At this point we have a shapefile containing the owners (one record pr owner with the parcels as a multipolygon).
Now we want the Atlas function to create the letter with each parcel on a separate page.
If an owner has three parcels he/she would receive a letter containing 4 pages – first page with some text and the following three with maps of each of the parcels
The question is: Is the possible?
Can the Atlas function dissolve (not sure if dissolve is the right word to use) a multipolygon into separated polygons and create a map for each?
Any comments and/or suggestions are greatly appreciated
Regards
Kaare
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151123/c1b376b8/attachment.html>
