[Qgis-user] qgis server does not return any data from WFS
Jachym Cepicky jachym.cepicky at gmail.com
Wed Nov 25 03:29:38 PST 2015
hi Stefan,
apache runs as www-data
the file is accessible via http://localhost/tmp/pokus/vrstva.shp -  so I
assume, it is readable by www-data
GetMap request as WMS works
GetFeatureType as WFS does not
thanks
Jachym
st 25. 11. 2015 v 11:38 odesílatel Blumentrath, Stefan <
Stefan.Blumentrath at nina.no> napsal:
> Is /var/www/html/tmp/pokus/vrstva.shp readable for user “www-data” (which
> is the default user for accessing QGIS Server I assume)? Or is that the
> ‘apache user’ you referred to or did you configure apache to explicitly
> access through another user than ‘www-data’?
> Cheers
> Stefan
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Jachym Cepicky
> *Sent:* 25. november 2015 11:28
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] qgis server does not return any data from WFS
> Hi,
> several days, I'm fighting QGIS server - on lightttpd now on Apache server
> with *same* result: WFS GetFeatureType request does not return any data.
> I created project, set all necessary metadat, coordinate systems, made
> sure data are in readable path etc...
> I've published the service using qgis_mapserver.fcgi - WMS works
> (GetCapabilitiers, GetMap, GetFeatureInfo), but WFS works just for
> GetCapabilitiers, GetFeatureType request returns just the first response
> element
> <wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:ogc="h .....>
> and that's all - not even the closing tag. It seems, the server refuses to
> work in the middle of construction of the response :-(
> I have
>             FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH /var/www/qgis
>             FcgidInitialEnv QGIS_DEBUG 1
>             FcgidInitialEnv QGIS_SERVER_LOG_FILE  /tmp/qgis-server.log
>             FcgidInitialEnv QGIS_SERVER_LOG_LEVEL  1
> but  /tmp/qgis-server.log is empty (even created)
> In the apache error log, only following lines can be found:
> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment
> variable.
> variable.
> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
> environment variable.
> variable.
> ERROR 4: Unable to open /var/www/html/tmp/pokus/vrstva.shp or
> /var/www/html/tmp/pokus/vrstva.SHP.
> BUT, accessing the file vrstva.shp from
> http://localhost/tmp/pokus/vrstva.shp works, apache user can read it and,
> as I already said: WMS GetMap and GetFeatureInfo works
> I've tested QGIS mapserver 2.12 and 2.8 on lightttpd as well as apache,
> with old projects as well as completely new with just one line in shapefile
> - same result all the time.  Ubuntu 15.10 btw.
> Any hint?
> Thanks
> Jachym
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151125/7bcd4026/attachment.html>
